928 Forum 1978-1995
Sponsored by: 928 Specialists
Window Trim re-anodizing
Old Feb 20, 2008 | 09:42 AM
dmw 85 Euro S A/T's Avatar
dmw 85 Euro S A/T
Default Window Trim re-anodizing
Anyone know where I can have all of my window trim and wiper arms re-anodized? I'm pulling it all off while I repaint the car. Dallas area preferred.
Old Feb 20, 2008 | 09:55 AM
Roger's Avatar
Roger
Anodizing is a process for aluminum. I would suggest having everything powder coated instead. Since you will pretty much be taking the car apart for the respray, it may also be beneficial to have the locks (around the key on the doors) done as well.
Regards,
Roger
Old Feb 20, 2008 | 10:08 AM
heinrich's Avatar
heinrich
928 Collector
Are they aluminium? I think it's basically thin steel .... you could have them plated.
Old Feb 20, 2008 | 10:42 AM
dmw 85 Euro S A/T
Hmmmm.... Powder coating does sound like it would be more durable. I wonder if power coating can be done in flat black.
Old Feb 20, 2008 | 10:46 AM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
I would be worried about the powder coating causing fitment issues.
Old Feb 20, 2008 | 08:34 PM
Podguy's Avatar
Podguy
Powder coating can be done in flat black as well as a number of levels in between. I do not see power coating causing much in the way of preventing the trim from fitting, but I would be more worried about chipping when installing the window trim. It has to be hit and formed a bit on installation.
SEM makes a very nice and forgiving OEM Black trim paint that captures the original finish nicely. Since it is forgiving it can be sprayed on as a touch up and still blend. I used it several years back when I was working on the convertible and it still looks good today. A can of SEM is a whole lot cheaper than stripping the old trim and having it recoated.
I do like powder coating - especially for engine parts, but powder coating can chip and surface prep is everything.
Old Feb 20, 2008 | 10:30 PM
6mil928's Avatar
6mil928
From: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
I just re did mine with black spray paint. They look awesome. Easy. Cheap. Last long time. Jason
Old Feb 20, 2008 | 10:58 PM
shadowknight's Avatar
shadowknight
I just had the wiper arms and door lock guards powder coated. The wiper arms came out great, but the door lock guards are made from a pot metal so the media blasting really did a number on them.
Old Feb 21, 2008 | 12:16 AM
928ntslow's Avatar
928ntslow
SEM all the way. Scotch pad to scuff them up, SEM primer then SEM trim black paint. Holds up for years! I did it to the 82 when I was in so Cal where it gets as hot as the surface of the sun. They never faded, chipped or cracked and lasted a long time. JMHO
Old Feb 21, 2008 | 12:46 AM
6mil928's Avatar
6mil928
Keith I forgot til you mentioned it but I too primed them first. Jason
Old Feb 21, 2008 | 01:54 AM
Nicole's Avatar
Nicole
Cottage Industry Sponsor
Another alternative would be to use high tech overlays. This is a super-thin material that won't ever chip, and you don't have to take the trim out of the seal to apply it. You can then chose to either use similar overlays on the corners, or paint those.
The complete kit is little over $20.
Or you can order a new set of trim pieces, which will come in black plastic.
Old Feb 21, 2008 | 01:21 PM
dmw 85 Euro S A/T
I think I'm going to look into the SEM solution. Thanks for all of the suggestions.
Old Feb 21, 2008 | 04:22 PM
JHowell37's Avatar
JHowell37
If you can't find any paint from SEM, look for some DuPont trim paint.
Old Feb 21, 2008 | 06:51 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
On my now-gone black Explorer, I used satin black rust-oleum spray on wiper arms and trim bits that were a little rock-blasted, and it held up great. I'm sure the SEM is a "perfect" match, but... Most don't have anything left on the car to compare with. If you do all the trim bits with the same color and finish, it's unlikely that you'll be able to tell the difference between SEM and a more-common, quality aerosol paint product applied with the same amount of prep. One guy's experience.
Old Feb 22, 2008 | 03:28 AM
Podguy's Avatar
Podguy
Dr. Bob,
Of course you are right. Rustoleum will work. it is a little more difficult to work with and it is far less forgiving. The thing I found out about the SEM finish is that even with a little over spray and uneven application it dries out almost prefect. The SEM vinyl paint also has this forgiving quality.
SEM is easily available in most Auto Body supply houses for reasonable $. Having done things both ways I gladly pay extra for the SEM products. Now some of us are professional painters - me I need all the help I can get.
