928 Forum 1978-1995
Sponsored by: 928 Specialists
Radio Reset
Old Feb 14, 2008 | 06:58 PM
Daymon66's Avatar
Daymon66
Default Radio Reset
okay. replaced battery and got the "code" light on the radio.
used the WRONG code like an idiot and then i got the "OFF" lights..
radio manual says that it will reset after being ON for 24 hours. i thought it was a misprint so i took the radio out for 3 days, reinstalled and same crap.
any words of advice???
1989 928, Factory CD2 Radio....
Old Feb 14, 2008 | 07:26 PM
ROG100's Avatar
ROG100
Basic Sponsor
Are you sure its the right code - did it work OK before?
If it reads ON for 24 Hrs try leaving it ON for 24 Hrs 8>)
Turning it off may not reset it.
Old Feb 14, 2008 | 07:35 PM
Gary Knox's Avatar
Gary Knox
All the Porsche/Becker radios I'm familiar with have to be left on with power in order to re-set. Just don't drain the battery!!!! These radios usually display WAIT when this time is expiring, and CODE (maybe flashing C) when it's ready for code entry again.
Gary Knox
Old Feb 14, 2008 | 08:56 PM
Daymon66's Avatar
Daymon66
so i'm gonna leave the keys on for 24 hours before this thing resets????? brilliant...
yes it worked before, not the cd but radio worked fine.
only code i have for it, and Sias said it was the right one.
thanks guys so much.
Old Feb 14, 2008 | 09:08 PM
ROG100's Avatar
ROG100
Basic Sponsor
Thats the whole point only the real owner would be able to do this.
Try the first position on the key so that only the radio is on and not the whole car.
Roger
Old Feb 14, 2008 | 09:18 PM
6.0-928S's Avatar
6.0-928S
Volvo says the same thing (24hrs) but usually it only takes two or three.
Hammer
Old Feb 14, 2008 | 10:00 PM
Daymon66's Avatar
Daymon66
will do.. thanks guys..
Old Feb 15, 2008 | 10:04 AM
Gary Knox's Avatar
Gary Knox
Daymon,
Go here and read the entire thread (22+pages). IF you don't have the right code, Loren may be helpful. Try the two codes he'll probably give you. IF neither work, then go plus and minus 1, then 2, then 3, etc. from the one he gives you. I found neither worked for a CR-210, but when I went plus 1 from his first code - BINGO.
Site is: http://www.renntech.org/forums/index...howtopic=14539
If that doesn't work, go to www. Renntech.org, scroll down to 986 boxster and click on that. Then scroll down to the third line which is "Lost Radio Code" and open that. Great source for radio help.
Gary Knox
West Chester, PA
PS: That thread also tells how to get the model number and serial number from many Porsche radio types without removing it from the dash.
Old Feb 15, 2008 | 10:13 AM
Daymon66's Avatar
Daymon66
very good information Gary. Thank you so much..
Old Feb 15, 2008 | 05:29 PM
Ispeed's Avatar
Ispeed
It was in the back of the glovebox manual, something like 12525 or something. You will find it there.Just punch it in when "code" comes up. It was playing cds when I owned it, may be cleanable or something. Poor radio reception though.
Old Jul 11, 2008 | 02:29 PM
Urockdude's Avatar
Urockdude
5th Gear
So guys,
Did the reset work? I had a power drain on the 968 I bought in the fall. Well, I have fixed the drain and now need to reset the radio. The radio was working until I entered the wrong code when I thought I was changing the channel. (that was the beginning of the power drain issues) Right now nothing comes up on the display. I tried it for 2 hours the other night and nothing....
