Momo No Mo' (how to get a Momo shift knob off - rv)
which type of momo ****? There different types with different mounting methods. There's usually a tiny retaining hex screw/bolt at the bottom of the ****. If you're absolutely sure it's not there, do what I had to do for my 911: twist it out with channel locks. (use rubber jaws to prevent unecessary destruction). Again, that was my case for the 911...never had to do it on the 928.
HTH
HTH
Thanx guys. Worked like a charm.
The consensus on the threads I searched seemed to be to leave the tension springs out when installing a short shifter. Any other thoughts or experience?
If you're using one of the purpose built short shifters, there is no place for the springs. If you're using a modified factory shifter, I think you either need spacers or the springs.
