I'm in the middle of replacing my steering rack on my 1986.5, but can't get the driver's side large inner tie rod bolt undone. Is it reverse threaded or what? I got the passenger side off OK (with a little struggle).
Any suggestions?
Eric,
Can be very tricky to loosen, as Greg said that's not reverse thread.
The best is if you can place a fork-spanner in a bench-screw-spanner (I do not know the correct name) and place the steering rack shaft in this Then you have both hand force free for loosen the tie-rod cap <img border="0" alt="[thumbsup]" title="" src="graemlins/bigok.gif" />
Don't twist/turn the steering house-shaft! <img border="0" alt="[nono]" title="" src="graemlins/nono.gif" />
I used a good-sized pipe wrench. Pictures and info at
<a href="http://members.rennlist.com/pirtle/svc_sr.html" target="_blank">http://members.rennlist.com/pirtle/svc_sr.html</a>
