Sway Bars- upgrade
Sway Bars- upgrade
Does anyone sell stiffer front and rear sway bars for the 928?
DEVEK used to have front bars but I don't see anything up on their new site.
928 Specialists no longer list their sway bars on their website.
I have a street/track 928 with Koni/Hypercoils and would like to upgrade the sway bars.
Greg Phillips
Greg Phillips
The specialist ones are nice and you get a front and rear for what some fronts costs ($500). Why anyone would spend $1000 on sway bars for a street car is beyond me.
I am a bad boy, i didnt read the entire post, this is for a track car, ignore the above
If you feel that your 928 has too much body roll then increase the spring rates that helps keep all 4 tires working and lessens the front end dive under braking. Sway bars/ antiroll bars borrow spring from the inside wheel and transfers it to the outside wheel. Poorly set up 911 race cars will often lift the inside front wheel off the ground in hard cornering but last time I checked tires on the ground have more traction than tires in the air !! In addition body roll is not necessarily all that bad a thing on a car like a 928 with double A arm front suspension where the camber change is designed to be better than a strut suspension.
Administrator - "Tyson"
Shame on you Ryan
Find an increased stiffness swaybar that doesn't. Avoid using the stiffest setting on the 928 Specialists bars and you're fine.
I've seen pics of 944s dragging their stock front bars on the track after breaking the mounts.
Greg Phillips
Greg Phillips
I may be able to help. email me at louie928@gmail.com
Fleet of Foot
