Euro fan belt tensioner?
I had on on my car until the bearing went south. I took it to a motor and pump shop. They could not see how the unit could be dis-assembled for bearing replacement. I'm going to try some ideas to make this thing work again because I would like to use it and many of those who have euro fan tensioners will someday face this problem.
Greg
Greg
The Parts Whisperer
The bearing use is very similar to the one used on the timing belt tensioner (928 105 512 12). I have with some success used one but it does require some machining and it is a pain.
Greg, when your bearing went, how did the pulley act? Is it supposed to spin freely? Mine spins well, no noises, but it stops spinning after about 4 or 5 revolutions.
Spins very freely. You could grab the pully and wiggle it a 32nd or so. The belt didn't run true and wiggled a bit with the engine running.
Mark, that was the direction I was headed, I wonder if it's worth the effort.
Greg
Greg
