928 Forum 1978-1995
Sponsored by: 928 Specialists
Vacuum gauge tuning
Old Apr 17, 2002 | 02:05 PM
Incendier's Avatar
Incendier
Post Vacuum gauge tuning
Hi all:
Anyone have an opinion on the best source for vacuum when doing a little gauge-based diagnosis?
Thx.
Old Apr 17, 2002 | 04:49 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Post
James wrote:
[quote] Anyone have an opinion on the best source for vacuum when doing a little gauge-based diagnosis?
<hr></blockquote>
I guess it depends on what you are trying to diagnose. If you are looking for ignition timing, valve timing, or plugged exhaust symptoms, attach the gauge to the full-port vacuum from the manifold. An easy place to find this on my car is at the hose that runs from the intake plenum to the solenoid for the flappy.
Another coomn spot for non-flappy cars is upstream of the check valve, where the hose runs down to the "accumulator" in the left fenderwell rear. I think the 'T' is by the brake booster. In the end, just about any non-ported source is OK, so long as there are no solenoids or check valves between the gauge and the engine.
HTH!
Old Apr 17, 2002 | 05:03 PM
Incendier's Avatar
Incendier
Post
Helps a lot; thanks.
You don't want to know what I'm hunting for...it's so unpleasant that I don't want to mention it in public.
Put it this way. I also will be doing a leakdown to see if my radiator is being pressurized...
It's been one thing after another lately.
Old Apr 17, 2002 | 06:39 PM
Randy V's Avatar
Randy V
25 Year Member
Post
Go ahead and tell us James - we can take it.
Old Apr 17, 2002 | 07:10 PM
Incendier's Avatar
Incendier
Post
H E A D G A S K E T.
Not sure yet, but all the signs are apparently there...eeeeeeeek.
Old Apr 17, 2002 | 08:42 PM
Randy V's Avatar
Randy V
25 Year Member
Post
Wally has a neat trick that uses a bicycle inner tube to test for leaks. Perhaps he'll share it with you - I can't recall the details.
Old Apr 18, 2002 | 10:28 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Post
You can make a quick and dirty tester to check for a blown head gasket.
Get an old spark plug, cut the ridge that holds the ceramic in and remove the ceramic center. Attach a piece of metal tubing long enough to get out of the plug wells, and attach a male air hose fitting. You can buy a plug adapter with an air hose fitting already made, but it may not fit down in the 928's plug wells.
Remove the plug in the suspect cylinder, use a two-foot wooden dowel as an indicator and turn the crank to put the piston on TDC. Remove the cooling system cap. Install the tester, hook to an air compressor and put air pressure in the cylinder.
If air leaks into the cooling system and bubbles up in the tank, you have a blown gasket or a cracked head.
Old Apr 18, 2002 | 01:07 PM
Incendier's Avatar
Incendier
Post
Thank you, Wally.
Randy, I think the inner-tube trick is to check for vacuum leaks - the tube goes over the intake throat.
Is this what you speak of?
<a href="http://ourworld.compuserve.com/homepages/nichols/tip367.htm" target="_blank">http://ourworld.compuserve.com/homepages/nichols/tip367.htm</a>
Old Apr 18, 2002 | 03:14 PM
Greg86andahalf's Avatar
Greg86andahalf
Post
James,
What are your symptoms which lead you to suspecting head gasket failure?
Greg
Old Apr 18, 2002 | 03:35 PM
Incendier's Avatar
Incendier
Post
Oh, the usual...although as of yet all unconfirmed.
Coolant in the oil, foamy crap in the oil breather, miss on the #5 cylinder, all following a recent overheat. Thought I caught it in time, but maybe not.
I hope I'm just being precautionary, because my baby has REALLY been trying the extent of my love lately.
Old Apr 18, 2002 | 03:51 PM
Randy V's Avatar
Randy V
25 Year Member
Post
No, the procedure I referenced was to use the bicycle tube on the cooling loop - perhaps it was for checking a leaking autotrans cooling system, rather than a leaking head.
Help me out Wally...
Old Apr 18, 2002 | 11:56 PM
WallyP's Avatar
WallyP
Post
Oil in the coolant and coolant in the oil may be a head gasket, or may be a leaking oil cooler in the radiator side tank.
The tester that Randy is referencing is a motorcycle inner tube (hopefully free or very cheap from a motorcycle shop, since you can use a blown tube) that is cut, and the ends placed on the radiator coolant connectors. You can then pump the tube and the radiator up thru the tube valve stem, putting gentle air pressure on the radiator.
By laying the radiator face down and filling the oil cooler with a solvent, or oil, you can then check for bubbles in the cooler connections.
If there is a leak in the cooler, oil will be forced into the coolant while the engine is running (75 psi oil, 15 psi coolant), and coolant will be forced into the oil immediately after shut-down of a warm engine (o psi oil, 15 psi coolant).
That won't make #5 cylinder miss, though. Air pressure in the cylinder is probably the surest test.
Since I just very stupidly overheated the engine in our Trooper, and now have 70 psi in one cylinder - and between 10 and 30 in the other three - I can sympathize. I think that mine will be cheaper to repair!
Old Apr 19, 2002 | 12:23 PM
Incendier's Avatar
Incendier
Post
Thank you all again; we'll see how she goes this weekend.
