E37 option code?? 84 928S2
Does anyone know what E37 stands for in the option code part of the rear mounted sticker?
Already tried several resources and found the meaning of my other option codes.
Thanks in advance.
Big AL in VA
84 928S2 euro twin distributor monster with large valve cut outs in the pistons, 85 stock headers, X-pipe, Cup wheels
Thanks in advance.
Big AL in VA
IIRC, there is an interlock so it only is armed when the sunroof is opened all the way.
If a passenger asks: "what happens if you push on the unmarked portion of the rear wiper switch", open the sunroof, and say: "try it".
I add large valve cut outs because I have one the the fist production automatic tranny S2s. On these Porsche used left over 83 pistons. The later S2 VINS got the high-compression pistons.
Big AL from VA
84 928S2 Euro twin distributor monster with large valve cut outs in the pistons
Big AL from VA
Big AL from VA
Big AL from VA
What difference would these pistons make in the big picture?
https://rennlist.com/forums/928-forum/318831-how-do-i-remove-16v-head.html
Big AL in VA
E codes are Exclusive department stuff. Known code list is incomplete.
http://members.rennlist.com/vilhuer/options.pdf
Code for low compression engine for Sweden and Switzerland is M151. It was available in '85-86 MY. Pistons these engines used are different than what was used in early '84 S2 MY engines.
Early '84 S2 MY engines used modified leftover '80-83 MY S pistons. PET shows engine number range they were used. Its all in another thread mentioned in previous message.
