alternator adjuster bolt size?
Due to a momentary brain fade when attempting to tighten my alt belt, I bent the tension bolt, and likely need to replace it. Does anyone know the length, diameter & pitch of this bolt so I can get a replacement before I tear into it?
TIA
Ken
TIA
Ken
Archive Gatekeeper
For what year? PET for '83-91 says part # N 010 248 1 M8 x 60. Dunno the thread pitch, but it's probably 1.25 mm.
Archive Gatekeeper
'78-82 says N 010 274 1, but no measurements. 928SP says M8x 75. $2.23.
Can you tell I should be working on my grant application instead?
