Failed VA emissions today (01/23/2008)
Not gonna happen this weekend guys, I am stuck working. Next weekend is a no go as well SO I guess I'll try to get to it on wed time permiting.
Michael
Michael
Michael,
Do you know if the O2 sensor was replaced previously? When I replaced mine, it was the original and rust welded in the exhaust pipe. If you can, start soaking it with penetrating oil ASAP.
I finally removed mine by removing the cat assembly, soaked it for a few days with Kroil, and then went at it with a torch, 22mm wrench and a bottle of wine.
If you're thinking of installing a crossover and highflow cats, this is a good time to do so.
Adam
Adam
So I failed again today after replacing the O2 sensor. Replacing the sensor dropped the HC and C0 #'s by about 60+/-.
I have put it off for 2 years so I guess it's time for the intake refresh to chase down a vacume leak. I have already ordered the intake and valve covers from Dave L. I'll be performing the surgery this weekend feb 16thth-17th and the following weekend the 23rd-24th if anyone is interested in helping.
I am also trying to decide if I wanna replace the injectors with Fords @ $40 each or doing the Witch Hunter service @ $17 per injector.
This weekend everything out, next weekend after getting replacement parts everything's going back in.
Bring yourself and a chair, as Beerfish has mine and enjoy the show.
Michael
Michael
Michael
I would like to stop by. Could you PM me your location and details?
I was running rich and found my MAF was sucking unmetered air. Found the MAF was not seated down inside and around the O-ring. And the smaller O-ring was missing.
Guys,
Sat would be best but I am imagining that I will be spending time under the hood both Sat and Sunday. So I guess lets say Sat starting at 2pm.
Michael
Michael
Ill be there late Sat when the drunk parts start getting lost, then back on Sunday. And yes, the chairs will join me!! Stop leaving your chairs at events Mike! =D
I am not sure there is a whole lot to do tomorrow other than clean.
Al and Bill showed up a little before 2 and Al got right in and started taking my engine apart while I scrambled for tools and supplies.
Here's a before pic:
Al had to leave at around 2:30 so it was just Bill and I and we kept pluggin' along. Here's a pic of our progress.
Around 5 or so Matt showed up and Bill had to head out. I was expecting the connections under the intake to suck but they were more diffucult than even that. By 7:30 or so Matt and I were just getting the last of the connections off and it was time to start cleaning.
So, all in all, not to bad of a job just took time. Nothing broke, just a bunch of brittle connectors and rotted wires. Now time to clean, clean and clean some more.
All in all a productive day.
Michael
Michael
