928 Forum 1978-1995
Sponsored by: 928 Specialists
New Vacuum Hose Kits from 928sRus
Old 08-12-2008, 06:01 PM
funkyboogalooo
funkyboogalooo's Avatar
hi Roger
How much is shipping to the UK?
Mike
Old 08-12-2008, 06:11 PM
ROG100
Basic Sponsor
ROG100's Avatar
$12.50 Priority Mail
Old 08-12-2008, 06:14 PM
southpaw51
southpaw51's Avatar
Hey Roger:
On a scale of 1-10 with 10 being the most difficult, how hard are these to install? Please advise. Jim in Tampa
Old 08-12-2008, 06:20 PM
ROG100
Basic Sponsor
ROG100's Avatar
You usually change out the vacuum hoses when you complete an R&R of the inlet manifold.
Completing an R&R of the manifold is about a 4 or 5 (I've done a few) on my scale. Plenty of detailed writeups to help you through the process.
I have never changed the vacuum hoses without removing the inlet manifold - maybe someone else has and can chime in here. It seems possible in theory but if it is in practice I don't know.
Roger
Old 08-13-2008, 12:29 PM
mj1pate
mj1pate's Avatar
Originally Posted by icsmike
What all is included? I just came back from a couple of parts houses with all lot of vaccum hoses, elbows etc. If yours is better I will take this stuff back. It ran me about $35.
Too late for me....I replaced all my hoses. But fine quality silicon hose plus those (expensive little bastard) T connectors ultimately cost at least the $65, but included several trips to the auto parts store plus a mail order. Your kit would have been welcome Roger.
Roger; I would also suggest an option to your kit that would include fittings plus a run to the auto transmission to replace the typically disconnected and hard-as-hell to repair vacuum modulator vacuum line. I rigged up a copper line running along side the brake lines, after too much head scratching concerning how to connect and provide strain relief.
Old 08-13-2008, 12:47 PM
mj1pate
mj1pate's Avatar
Roger
Right you are Roger; I was able to replace most of the hoses except ones that terminate on fittings in front of the air riser. The hard to replace hoses on the back of the riser were replaceable. A bigger reason to remove the intakes at some point is the air breather hoses that by this time (if unreplaced) are as hard as stone (no figure of speech).
Old 09-12-2008, 10:05 AM
Stan.Shaw@Excell.Net
Stan.Shaw@Excell.Net's Avatar
I bought the replacement elbows from you, but think I found something like 7 of 10. Any chance you have, or can point me to, where the elbows are located so I know I got them all (90 GT)?
Old 09-12-2008, 10:39 AM
the flyin' scotsman
the flyin' scotsman's Avatar
carbon canister, flappy switch x2, front and rear fuel dampers, fuel reg, air pump valve and the 3 under the throttle body...............IIRC
Old 09-12-2008, 10:51 AM
Any chance there is a photo pointing their locations out? (I can hope, right?)
Old 09-12-2008, 11:03 AM
the flyin' scotsman
this should help Stan:
Old 09-12-2008, 11:05 AM
SeanR
SeanR's Avatar
Direct from that site.
Old 09-12-2008, 11:11 AM
thanks!
Old 09-12-2008, 12:15 PM
DonS
DonS's Avatar
Location: Live Music Capital of the World - Austin, Texas
Speaking of vacuum lines, when I checked mine they ALL were the hard plastic 3mm? size except for the elbows and end connectors. Which ones are the larger size and should it matter if I don't have them?
Old 09-12-2008, 12:32 PM
ROG100
Basic Sponsor
ROG100's Avatar
all the vacuum lines on the later cars 85 and onwards are 3mm hard plastic lines as per my kit.
Old 09-12-2008, 12:34 PM
DonS
DonS's Avatar
So those would also be okay on my '84 S?
Quick Reply: New Vacuum Hose Kits from 928sRus
