2 ??'s on under hood ing source on 86
? 1
Need to hook up my Temperature control relay and need an under hood ignition on source.
? 2 if I was to hook up the ignition source to the power post would this provide a fan on until the temp is reduced or would it stay on too long and drain the battery.
Feedback![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Mark
Feedback
Mark
Gluteus Maximus
? 1
Mark
Feedback
Mark
Hooking the power side of the relay to the power post (properly fused, of course) would seem like a good idea since it'll carry plenty of current for the fan.
Team Owner
you might find a switched power supply in the 14 pin connector above the hot post, not sure what wire though
it is not too difficult to run a wire through the firewall (going under the dead pedal) that could go to a switched source where the fuse panel is. I did this and it took about 1/2 hour to 45 minutes.
Sharkaholic
When I installed Carls spal fan kit, I went with the hot post in the engine bay, and when I shut the engine down the fan only runs for a couple of minutes before the temp switch shuts it off.
Someone correct me if i am wrong, I think that on DR's twin screw fan setup one fan uses the Jump Post as a power source with a temp switch to excite the relay coil, and the other fan taps the existing wiring from the AC/Aux fan.
Inventor
85- have switched 12V+ at the ignition coils (unfused, coils are marked ±, - is the spark trigger).
Easy crimp terminal connection, too.
-84 have a resistor before the coil.
