Big Blacks and 16 inch wheels
86.5 and S4's had big black's on them with S4 flat disc wheels on them.
why would they not fit? the wheels were 16 inch.....
15" phone dials definitely won't work?
--Russ
--Russ
I think the "Big Black's" he's referring to are the GTS front calipers which are the same size as 993 TT's, just a different color. They will not work with 16" wheels.
So yes stock S4 302mm 4 pistons will fit....the 322mm 4 piston will not fit
Rest in Peace
Rest in Peace
Agree 16's won't fit over Big blacks/big reds. The 951 guys also had the medium S4's as part of the M030 package. These will fit 16's with the smaller rotor. The medium S4's used on the 91-92 turbo with the 322mm rotor might, but not sure. These use the same pad but the larger rotor than the 928's. The casting is different but I don't believe it is as large as the big blacks/reds by 10mm not sure if it is that much smaller that it would work, but might be worth a look. Wouldn't gain you any clamping force but would gain you additional swept area.
928 Collector
It might be possible that some manufactures design might work although not recommended. I have a TSB at home that states you should not use any of the 16" Porsche wheels over the big blacks/reds I will look it up when I get a chance.
