Knocking Noise??
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
History:
I have just replaced my timing belt. I also replaced my front and rear gaskets and seals on my left side cam. I rebuilt my belt tensioner and bought a new rubber top for it.
Problem:
I had a knocking noise in my engine. It almost sounds like a clicking noise in the distributor. I timed the cam gears with the pulley and checked my firing order, it was all lined up. I thought it was the timing belt whipping against the covers. When I replaced the belt which was original and my car has 113,000 miles on it, thank god for having a 1979 928
, it still made a knocking (clicking noise). I also thought it could be a lifter, but don't want to take it apart until I know the problem.
It has been about 6 months since I drove it, and only got to drive it one day after I replaced my clutch and then my timing belt needed to be replaced. <img src="graemlins/crying.gif" border="0" alt="[crying]" /> If anybody knows the problem please reply to this message.
Thanks alot,
Shawn
Problem:
Thanks alot,
Shawn
928 Engine Re-Re-Rebuild Specialist
I've got a slight ticking noise coming from my engine as well. Last week two other shark owners popped their hoods for me. All 3 cars have the same clicking which I assume is the injector. I also assume it's not a cause for concern.
If I recall correctly, someone here (ah yes, 'twas Moss928) had similar symptoms that turned out to be a failed cam bolt.
See:
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=14&t=000373" target="_blank">http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=14&t=000373</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=14&t=000385" target="_blank">http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=14&t=000385</a>
See:
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Thanks for all your help. I have found the problem. The gear on the end of the distributor was cracked and bent up making the gear in the cam push the distributor up and down.
I have ordered a new one from 928 International for $64.00, and should arrive tommorow. I hope this fix's the problem.
Thanks,
Shawn <img src="graemlins/a_smil17.gif" border="0" alt="[blabla]" />
Thanks,
