A/f Hook-up ? Forgot the answer ;(
Need to hook up my A/F meter which signal wire goes to the A/F gauge off of the Ox sensor ?
Ox sensor:
white/white one connector
Black: single connector larger wire hooks to car green wire
Should I fuse the power?
From Car:
Brown/ Blue one connector
Large: Green wire with barrel connector
A/F gauge
Black to ground
Red to power
Purple to ???
Ox sensor:
From Car:
A/F gauge
Black to ground
Red to power
Purple to ???
taking from the lighter is fine if you are not using the factory cigarette lighter.
I would not draw from the fuel pump as suggested. IMO it already has too much load.
I found it was the black wire:
Has anyone inserted the vacuum tube for the boost gauge, where is the best spot to do this I'm using an ashtray pod.
seriously doubt it. manifold vacuum and pressure should be the same at either place. I see no need to go into the engine bay to pick up the line, but I could be mistaken.
