Can't find my coolant leak
Any ideas where i'm leaking coolant from? I can't see any obvious leak from either of the rad hoses, the hose too the expansion tank, or anywhere else for that matter. Also, i used a syringe to drain the coolant from the top of the block last week, when i check today, the coolant has re-appeared!
What Ketchmi said. The bottom water bridge o-ring is a common leak source.
Bert,
The thermostat housing is only connected to the cylinder heads by 4 allen head bolts. Some say that you can remove these bolts without intake removal. I tried this and couldn't find a wrench for the job. I finall replaced the rubber seals when I powdercoated my intake. Without the intake it is a 5 minute job.
I had a leak in a similar location and it turned out to be the hose going from the bridge to the coolant reservoir that had a split just at the end of the connection fitting in the bridge. It was not obvios until I pulled the hose off. The hose has to come off to do anything else on the bridge so check out the hoses before you dig to deep.
