How does this look (Fuel Pump Install)
Team Owner
I would write a date and milage on the new filter in a spot above the bottom , so if it leaks it wont erase the info, use a sharpie and cover it with some 3m clear package tape, so in 4 years you will know or the next owner will know what time /when it was replaced
Good idea....with this little note....gas is a solvent...so if it leaks....so much for the ink...ask me how I know.....
Word of caution...the little copper washer can only be used once, unless you torch them to re-anneal them.....also be cautious of how much torque you put on the crossover pipe from the pump to the filter...it will crack and leak (again ask me how I know)
