Caliper pistion diameters
Anyone know the diameters of the pistons in the S4 front/rear calipers? Also, the diameter of the master cylinder? I recently bought James Walker's brake book (good one) and want to plug actual numbers into his formulas.
Thanks,
John
Thanks,
John
Wasn't there a different piston size in 87 vs 88 on. I was thinking this is why there haven't been caliper rebuild sets for the 87. Please correct me if I'm wrong because I am getting ready to take apart my 87s brakes and was just going to clean and reassemble.
Yes, the piston size did change on the "S4" calipers. Andrew shows it above. 86.5 and most of 87 had 42 and 36 pistons. Sometime in 88 they went to 44 and 36. then in 1989 the pistons stayed the same, but the dust seals changed.
46-6c of the Workshop manual:
Note
From 1987 models on*, the front brake caliper
piston diameters were changed to 44/36
mm (previously 42/36 mm).
During the 1989 model year, a further modification
was introduced. The piston seal was
changed from the scraper ring type to the protective
cap type. (Technical Information Gr. 4
No. l/69) Notes on replacement: refer to
Pages 47-04 I 4705.
l*On some cars (those for the USA, Canada, Australia and Arab countries), fixed calipers with piston
diameters of 42/36 mm were still used in the 1987 model year. For notes on replacement, refer to
Page 47-04.
Note
Pages 47-04 I 4705.
Page 47-04.
Chronic Tool Dropper
I know that my fuel comsumption is higher at 70 than at 55. Mostly because I get to slow down for folks cruising at 55 in the left lane, and accelerate back to 70 once I can do a totally unsafe pass-on-the-right, after flashing to alert them that they might be in the wrong lane.
Traffic congestion here is a big subject of discussion these days. It's time to step up and remind our lawmakers that we can fit twice as many cars on the same roads for half the time if everyone would drive twice as fast as they are now. Congestion is caused by people who drive slow. In front of me.
Yes careful with those '87's... they are different and the seals not available anywhere. The only solution I was able to find (and abandoned) was all new pistons. ick.
