Shift handles f/Jager Engineering/steering wheels
[quote]Originally posted by DR:
<strong>The AJ version looks the same with the exception that it doesn't have the embossed Porsche crest in the horn pad like the Genuine Porsche version, BUT more importantly the AJ version is not made specifically for a 928 and is mounted with the use of an adapter kit (some 928ers have reported problems with installation and returned them). The Genuine Porsche 928 Sports wheel is made for a 928 only and installs and fits just like any original factory wheel, i.e. no adapters.
While the quality of the wheels are probably the same and I would guess they are made by the same factory, the AJ version is a univeral fit via adapters and the Porsche version is model specific.</strong><hr></blockquote>
Very good info, thanks for the clarification David.
This helps explain why the AJ's folks try to sell you (as a separate item) the "Porsche cloisonne crest" for the horn pad!
Which prompts another question that perhaps Mr. Roberts can answer....
I recently saw a 2002 996 at a P-dealership that had this "Sports Steering Wheel" option, but also had the cloisonne crest on the horn pad.
Is this also available on a 928-specific part # wheel and, if so, does the wheel carry a different part # or suffix code ???
Or must the cloisonne crest be ordered separately and owner-installed ?
Thanks DR, <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
Brad
'78 <a href="http://www.p-caronline.com/directory/showngo/" target="_blank">928 euro</a> 5 speed
928 Owners Club
Brad
928 Owners Club
Rennlist Sponsor
[quote]Which prompts another question that perhaps Mr. Roberts can answer....
Thanks DR,
<hr></blockquote>
Hi Brad,
The only 3 number car I know anything about is a 928 !! :-) I know nuthing about those 996 critters. SO I can't say for sure if the wheel you saw had the colored crest from the factory or not. In the listings I have seen there is only one part number for a 928 and I only remember one part number for 911s.
The colored crest you speak of is a separate Porsche part. Believe it or not it is the hood badge for an old 356. The Porsche part number is 644.559.210.00 and sells for around $34.
The crest has post/pin on the back for mounting, some perople say to put a hole in your horn pad to mount it but I personally have a problem with putting a hole in a $400 leather steering wheel. I prefer the process of breaking off the pin and using a mild silicone adhesive to glue it in place. That way it can be removed later if desired.
BTW, you are very welcome!!
Thanks DR,
<hr></blockquote>
Hi Brad,
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
I brought this up in an earlier post with no reply, does anyone have any experience with this item:
<a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1854099968" target="_blank">Ebay Item</a>
I'm thinking about this with one of Jeager's boots and stainless PRNDL
Former Vendor
Here is my take on the subject. When I bought the shark, the PO had the original T-handle "duck-taped" to the post. So I didn't have much choice.
The steering wheel and the Jager handle are my first customizations.
The handle was easy to install and works great. One thing important to add is the excellent service that Paul Jager provides. He really goes out of his way to accomodate.
I just thought I'd chime in with one other Jager shifter cheer, so to speak. I find myself actually using the ability to drop it down into the lower gear more often than I did with the T handle. I can't say it completely fulfils my desire for a 5-speed, but it's the best compromise I can think of, not to mention fun to use. Though I do have to say this: the shifter will not *completely* stand up to being hit with the end of an entire exhaust system from cat-back being shoved through from the hatch--So, watch it with those pipes!
(P.S. if you've had this problem, a dab of gasket seal will treat you right.)
[quote]Originally posted by Champagne:
<strong>The steering wheel and the Jager handle are my first customizations.</strong><hr></blockquote>
Paul, I just have to say that that wood wheel looks GREAT and really suits your exterior paint/interior color combination.
VERY nice !!!
Brad
928 Owners Club
VERY nice !!!
Brad
928 Owners Club
