928 Forum 1978-1995
Sponsored by: 928 Specialists
Temp Regulation Issue
Old Oct 19, 2002 | 10:03 AM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Post Temp Regulation Issue
The weather is chilly and my HVAC is not regulating cabin temp.
Basically, unless the slider is all the way to the right the temp is cold.
I listened the air mixture motor and only hear the flaps move if the temp slider is in the full heat position or off the full heat position. Basically full open or closed.
I had the flaps adjusted this summer chasing a cooling problem and remember the readings being correct as I slowly moved the temp slider.
Any help?
