928 Forum 1978-1995
Sponsored by: 928 Specialists
Need a Wheel Lock Socket.
Old 12-26-2007, 05:14 PM
  #31
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by Randy V
I've received the kit from Greg (Blown 87 - thanks, bud) and the replacement lugs from 928 Intn'l.
I think I'll give 'em a whack later today.
I hope they work for you Randy, keep them as long as you need them to do yours and Bill Swift's if he still wants to do his.
We have other ways to get them off if we need to do that, so no hurry on them.
blown 87 is offline
Old 12-27-2007, 04:44 PM
  #32
Randy V
Randy V's Avatar
Well, the first attempt resulted in the 'crown' of the wheel lock shearing off - as it's designed to do, I imagine.
The tools Greg provided do not have a socket that fits around the 'base' of the wheel lock.
Any suggestions, Greg?
I do know which OEM wheel lock socket is required - a '009' (from memory). I had written it in the owner's manual last time I got a replacement.
Randy V is offline
Old 01-02-2008, 07:48 PM
  #33
Randy V
Randy V's Avatar
Still stuck.
Randy V is offline
Old 01-02-2008, 08:06 PM
  #34
Alan
Electron Wrangler
Alan's Avatar
Uh Oh...
Do you have a carbide tipped dremmel, cutting wax, a very steady hand, lots of patience and 2-3 hours to spare...
Hope it doesn't come to that...
Once you get it off throw them all away... go with regular lugnuts
Alan
Alan is offline
Old 01-02-2008, 08:37 PM
  #35
Garth S
Garth S's Avatar
I don't suppose you are yet desperate enough to custom form a socket caviety with saran wrap and JB weld ?
Seriously - I did this on a VW 'security' wheel bolt: one was different than the other three .... about 5 min of work + set up time for the epoxy. Saran wrap or a spray of WD-40 is the release agent. Got a pic of the nut .... so one can see what will work?
Garth S is offline
Old 01-02-2008, 09:11 PM
  #36
heinrich
928 Collector
heinrich's Avatar
Hey Randy ... the factory socket will still work, and you know the number, so just order one.
heinrich is offline
Old 01-02-2008, 09:15 PM
  #37
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
I'm thinking I'm glad I didn't run out and buy those sockets yet! I have the same locking lugs that Randy does... I think I'll pay the local p-car dealer a visit. Randy, you may want to make your way down to Miramar and see if they have the correct socket. Maybe they will take pity on you.
I'd better get there before you do tho...
Bill51sdr is offline
Old 01-02-2008, 09:53 PM
  #38
IcemanG17
IcemanG17's Avatar
Hmm....what about one of those "fits anything" sockets with all the metal pins on the inside that push back into whatever lugs there are while the high spots slide back into the socket?? if it will fit inside the rim it should work?
http://www.asseenontv.com/prod-pages/gatorgrip.html
Okay its called GatorGrip....I've seen similar items at the local Sears?
IcemanG17 is offline
Old 01-02-2008, 10:35 PM
  #39
AO
Supercharged
AO's Avatar
Light it on fire and call the insurance company.
AO is offline
Old 01-02-2008, 11:05 PM
  #40
Alan
Electron Wrangler
Alan's Avatar
Nope - won't work on these because the key slots are little 45degree triangluar ramps around the outside edges. This profile is also what makes the key sockets expode if you over torque them - since it puts major expansion forces directly to the perimeter of the socket ring - At some point it just fractures into pieces...
If its not over torqued the correct socket is easily the best bet for removal. Stronger sockets would be good...
Alan
Alan is offline
Old 01-02-2008, 11:12 PM
  #41
dr bob
Chronic Tool Dropper
dr bob's Avatar
Randy--
I don't know the number on mine, there's none on the key I have. My guess is that there is no good way for you to see if mine will fit without trying it, right? Below is a not-spectacular picture of one I have.
An option you have is what another suggested-- Take an old socket that just fits over the outer part of the lug nut. Use an old 3/4". Put something in the botton of the socket (like a penny...) to keep the epoxy from pushing through the square hole there. Spray mold release (silicone spray) on the lug it and let it dry. Mix up some 5-min paste epoxy, the kind you get in the two sticks that you mix together. Line the inside faces of the socket and the bottom, thick enough to form around the lug when you press the socket over it. Then press the socket over it. You need to press it hard enough to get the impressions in the epoxy, then carefully withdraw it without turning it at all. Make sure your impression is good, reform your epoxy and press it in again if necessary until you get it right. Let it dry overnight before you actually try it on the lug nuts, of course.
dr bob is offline
Old 01-02-2008, 11:29 PM
  #42
blown 87
Rest in Peace
blown 87's Avatar
Randy I can send you the other set I have, I can send you some pics of them in the AM.
Can you post a picture of what is left of the lock?
There is always a way to solve a problem.
blown 87 is offline
Old 01-03-2008, 11:05 AM
  #43
blown 87
Rest in Peace
blown 87's Avatar
Randy would something like this work?
I have the metric set in 3/8 drive deep well.
http://buy1.snapon.com/catalog/item....re&dir=catalog
blown 87 is offline
Old 01-03-2008, 11:35 AM
  #44
heinrich
928 Collector
heinrich's Avatar
See post number 2 here https://rennlist.com/forums/showpost...57&postcount=2
heinrich is offline
Old 01-03-2008, 11:48 AM
  #45
Randy V
Randy V's Avatar
That's what I'm thinking as well.
Randy V is offline
Quick Reply: Need a Wheel Lock Socket.
