ID Mystery Timing Belt
I am wondering if this replacement timing belt is the wrong one. Would you say this is a square tooth or a round tooth belt?
<img src="http://www.flash.net/~ego/tbelt03.jpg" alt=" - " />
It has characteristics of both doesn't it; it looks like they tried to make a "one size fits all." Other items I'll get from the local supplier, but not the T-belt. Going to the big 3 will prevent this identity problem. The real question is how will it perform? <img border="0" alt="[nono]" title="" src="graemlins/nono.gif" />
The bag it came in had two labels that matched for the desired belt. It's an aftermarket belt from Zims and is not universal - has a specific Porsche part number. A friend thinks it was a mistake, gave the belt to me, then bought a Gates/Porsche labeled belt from the dealer. Before I say which it is supposed to be, I wanted to get some opinions on which one you think it is.
I have heard that using a belt that doesnt fit properly in the teeth of the sprocket will wear the squareness off the sprocket teeth, thus making it possible to slip a tooth sometime in the future...
Here's the scoop on the belt from Zims, passed on to me by Bob in the DFW928 group - Zims says, "It is a legitimate late model belt produced
only by the Flennor company, A German Co. that Zim's has used for years. The reason for the flat bottom with the groove in it is an improvement said to give dirt a place to go, lessen wear, & quieter running with less
whistle. It is strictly a late model belt, not only are the teeth deeper, but they also
have a different number of teeth."
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Steve J.:
<strong>Here's the scoop on the belt from Zims, passed on to me by Bob in the DFW928 group - Zims says, "It is a legitimate late model belt produced only by the Flennor company, A German Co. that Zim's has used for years. The reason for the flat bottom with the groove in it is an improvement said to give dirt a place to go, lessen wear, & quieter running with less
have a different number of teeth."</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">That's the first time I've heard of the belts having different number of teeth! I have heard of people mixing them up, though. If the tooth pitch is the same, then it would make for a different *length* belt.
