help torque specs 85 euro rack & pinion
i need the correct torque specs for the the 4 large bolts holding the rack & pinion , 1 bolt to the frame and and the 4 smaller cover nuts . also the tie rod ball joint nut as well. after stopping the leaks i need to reinstall everything now. got some great advise from the forum.
thank you
thank you
4 bolts steering gear to engine carrier 46 NM , tie rod to steering arm 85 NM , u-joint to steering gear 23 NM, tie rod to ball joint 45 NM , steering tie rod to rack 150 nm , feed and return lines on steering gear 30 NM ,stabilizer clamp to side member 46 NM .
