replacing steering wheel.
Hello everyone, is my once again.
I bought a Momo steering wheel and can not find a way to get the stck one out, help please, I don't want to damage it.
Any takers???
Thanks in advance.
Walter 88 928 S4.
Any takers???
Thanks in advance.
Walter 88 928 S4.
Assuming it's NOT an airbag car;
1 Grab ahold of the hornpad on both sides
and give a sharp hardy yank.
2 Look down inside and you'll ses the nut
that holds it on
3 Grab ahold of the wheel and shake/wiggle
it off.
that holds it on
it off.
The horn pad is held on by three prongs that release when you pull out of it. Do it carefully and it will come out. I pulled at the top and side to remove mine.
Then there is a 27mm bolt that you have to remove. Also, you will see where the electric connects to the horn, disconnect this.
Nope....an 88 didn't come with air bags.
Several methods that will work have been mentioned. My favorite is the grasping both sides of the horn pad and giving a quick & firm tug to remove it.
The wheel itself is held on as mentioned above with a 27 mm nut. When you replaqce the weheel - be certain to torque this back tot he correct value - 36 ft-lbs is what is caled for I believe (look this up - or re-post for the correct value).
btw - some of the MOMO wheels require an adapter to the keep the wheel off of the Pod - and the wiring will most probably require an additional piece fabricated to make the horn button work - my Club 4 did anyway.
hth-
hth-
I need a steering wheel Mine is all messed up. How much for your old one? I don't need a great one just as long as the leather is mostly sewn on .Cheep would be good. It don't hurt to ask.Thank Brittany brittanychenli@yahoo.com
