Marker light delete in progress
Rest in Peace
Front fenders off (that was a bitch) patch panels cut, and a big thanks to ROG for the patch panels.
Ready to weld in.
I will post some of them welded in.
Ready to weld in.
Rest in Peace
The biggest reason is I am not that good a welder.
Chronic Tool Dropper
Aluminum 928 fenders are probably not the right place to hone your welding skills. Plus, all that pretty filler will need to come off. Or it will come off when the welding gets underway and the panel there gets hot. In the meanwhile, practice your aluminum welding skills on pop cans. You can still get your deposit back on those if you warp them.
Rest in Peace
I have a pro coming to the shop to do it for me.
The undercoat should be a urethane base, not the asphalt/petrol based crap they sell at autozone. "Moisture bleed-through" should not be a problem unless you hired a ****ty welder. But as a general rule there's no need to take chances. As I said make sure you get the urethane based undercoat. On the outside, you're going to need some filler once you grind down the welds. Get some fiber-glass reinforced filler. It doesn't matter whether you use long strand or short strand. Short strand is easier to use. So use it if you have the option. Fiberglass reinforced filler is highly water/moisture resistant. After that, you can go to either a glazing filler or straight your epoxy or high-build.
Rocket Pilot
Anyone else doing this mod should use SEM panel adhesive or equivilent. Welding aluminum on the 928 is tricky at best, and looking at those welds you see my point. I will be doing this soon as well. Jhowell37 offers good advice in his post.
Kevin
Kevin
Cottage Industry Sponsor
I have never met anybody who does. They look like an afterthought, and it shows when you need to change a bulb.
Since not everybody is in the position to delete them, I try to offer at some relief with the clear lenses, and the long lasting LEDs.
On my own car I tinted the markers to be as close to the body color as possible, making them a lot less obvious. It's as close as I could get to deleting them.
Andrew Olson tinted his front markers red on his red car, and I've done a black tinting job on a pair of the lenses.
I leaned that unless you want the tint to be really, really dark, you get the longest lasting results by tinting the inside of the clear lenses, and the best look when combining the tinted lenses with black housings.
If you want to go really dark and need to tint on the outside, don't forget a layer of clearcoat, so the tint is protected from scuffs, chips, polish, and other bad influences...
