rough idling and power loss
hi
my car occasionaly seems to rev high and then low when at a standstill and sometimes stalls, a few of the gagues also seem to go up and down in time with the revs there is also a slow uptake when accelerating. this is obviously causing concern and i was wondering if anyone could shed some light on the situation
cheers
Tim 84 s2 auto
cheers
Tim 84 s2 auto
Cottage Industry Sponsor
Does your model have an idle control valve, like the S4 models? The symptoms sound like what I have experienced when the idle control valve was going bad. There are tricks to lubricate it - if it applies to your car, do a search!
If you are having power loss, it is reasonable that the idle circuit is involved, but more likely something beyond that.
Sounds like same symptoms I experienced that two caps, rotors, and wires fixed. Wires go bad frequently in '28's.
Good Luck.
Jeff
'87 5-spd.
chips, RMB, Ott
Good Luck.
Jeff
'87 5-spd.
chips, RMB, Ott
hi
i took all the plugs off and sprayed a little WD 40 around them the coil and the distributer
fired her up and she ran smoothly
maybe cured the problem for a while. i will see how long it lasts
thanks for the help
cheers
Tim 84 s2 auto
thanks for the help
cheers
Tim 84 s2 auto
