OBD-II retrofit
Would sombody please develop a computer retrofit for these older cars so that we can use the OBD-II stuff. Just take out the ignition brains and the Jetronic brains and put something modern in that we can interface with a laptop.
It seems like it would be a valuable product for not just the 928 guys but all cars with the older Bosch injection systems. 911's, Benzes, etc...
We could switch over to MAP at the same time to get rid of that finiky Hot Wire.
Am I wrong in thinking this would be a cool aftermarket improvement?
There's plenty of poople out there that will sell you an engine management system for your 928, with a computer interface. The one I've got my eye on is:
<a href="http://www.dtafast.co.uk/" target="_blank">DTA fast engine management systems</a>
Which seems V capable and flexible.
They emailed me some prices (not listed on their site):
END USER PRICE LIST
ALL PRICES IN UK POUNDS
MULTIPLY BY 1.60 FOR US$ (APPROXIMATE)
E48EXP ECU
IGNITION ONLY 350.00
IGNITION AND FUEL 550.00
P8PRO ECU 850.00
ACCESSORIES
SERIAL CABLE (2M LONG) 45.00
COMBINED SERIAL AND CONTROL BOX CABLE
WITH ATTACHED CONTROL BOX (5M LONG)
195.00
CONTROL SOFTWARE FREE
55 PIN P9 CONNECTOR KIT 28.00
25 PIN E48 CONNECTOR KIT 6.00
INJECTOR CONNECTORS (WITH BOOTS) 2.50
OTHER CONNECTORS POA
3.0 BAR PRESSURE SENSOR 80.00
1.15 BAR PRESSURE SENSOR 80.00
RACE QUALITY E48 HARNESS (STD) 295.00
IGN ONLY RACE QUAL.E48 HARNESS 110.00
P8PRO LOOM TO SPEC. POA
CRANKSHAFT SENSOR 30.00
CRANKSHAFT WHEEL (138MM DIA) 45.00
CRANKSHAFT WHEEL (100MM DIA) 45.00
AIR TEMP SENSOR 22.00
WATER TEMP SENSOR 18.00
THROTTLE POTS VARIOUS (APPROX) 39.00
4 CYLINDER COIL 50.00
SPECIAL LOOMS POA
INJECTION HARDWARE AS WEB SITE
INJECTORS 50.00
O2 SENSOR (4 WIRE EU3 SPEC V.GOOD)
98.00
Cheers
Dave
END USER PRICE LIST
E48EXP ECU
P8PRO ECU 850.00
ACCESSORIES
195.00
SPECIAL LOOMS POA
INJECTORS 50.00
98.00
Cheers
Dave
You can also check out Perfect Power's PRS8 unit. Its around the same price or so (Louie Ott sells them) and it uses Windows software instead of DOS. They both are quite comparable in features, so check them both out. <a href="http://www.perfectpower.com/products/prs.asp" target="_blank">http://www.perfectpower.com/products/prs.asp</a>
So I guess I'm wondering how much work on my end it will be to install one of these.
Also, will I be able to pass smog? The smog tech never checks the computer as far as I know.
None of the systems mentioned would be OB2 compatible. The market for aftermarket ignition/injection systems is relatively small and for Benzes vitrually nil. It's only for enthusiasts who have the time and ability and money to install. For a stock car what would be the gain?
Resurrecting a 17 year old thread. I have a 96 MB G320 imported by Europa and am looking to add an OBD2 port. In the intervening years, has anyone added one to their pre-OBD2 cars?
