Horn pad cover? Please tell me how to install it!!!!!!!!
Please tell my how to put this on my horn pad. I've never worked with leather before, haha.
Team Owner
well.................... first i think you have to remove the old leather. BUT.............. before you do it would be wise to measure the old leather VS the new stuff, the old stuff looks like its thinner and you may not be able to secure the thicker leather to the pad.
I would recommend brush on yellow contact cement put it on both sides and let it sit for a while then tack it together
Artist Formerly Known As 84totheFloor
Who stitched this pad for you? It appears you have too much material, both in area and perhaps in thickness. Is the rest of your steering wheel releathered? If so, it might be a bit tight getting thick leather on to the pad.
Paul Champagne or Rob Budd are your best go-to guys for specifics here.
Lots of glue.
Hope that helps.
Hope that helps.
Use Wilwood's glue from Home Depot, its a contact cement in a red can. You need to clean the horn very well before putting the glue on, just apply the glue to the face of the horn first,dont worry about the edges yet,then after putting the glue on let it dry for about 5-10 minutes then install the cover smooth everything out,(the face of the horn) dont do the edges yet. MAKE SURE ITS STRAIGHT. Let it all dry for 30 minutes then figure out where the leather needs to be trimed to clear everything on the back, then add glue let dry for a few minutes then stretch it on and apply firm pressure. Im not an expert at this, Rob may have a beeter way of doing this, just telling you how I would do it. Might want to e-mail Rob though.
Good Luck
Good Luck
I got it! Took me about fourty minutes, but I think it looks great. I went with the glueing part. Not bad for my first time eh? Now on my way to getting my seats recovered, woot!
Team Owner
944 dash, ahh used to have a few of em
