Found broken spring in transmission pan. Where could it go?
Hello,
I am in the middle of a transmission fluid and filter change. When I lowered the pan, I found part of a broken spring the pan. It is about 3/4" long and about 3/8" or 1/2" in diameter.
I'm going back outside to look around, but if someone could help steer me to where the spring may have come from, please let me know. I'll check back in a little while.
Thanks,
Greg
Thanks,
Greg
the only spring that i know of is the one that is attached to the white plunger under the trannny so check if it still goes in and out.i am also having problems with my tranny
hope this will help
Tim
84 s2 auto euro
hope this will help
Tim
84 s2 auto euro
Thanks for the reply.
The plunger (if I'm looking at the right one) does spring back.
This is a hook type return spring that I found.
Could give return action to something, or could be used to hold something in place.
Still Searching.
Greg
Still Searching.
Greg
I think I have found it in the service manual. I think it is the "engage return spring". Now to find that part on the trans. The picture is an extreme close up and there is little in the way of a reference point.
Still hunting.
Still hunting.
That spring is for the throttle valve lever; the TV cable is attached to the lever.
Steve C
The Great White
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Steve C
The Great White
The kickdown cable attaches to a J-hook assembly, on the left side of the trans, that is spring activated.
Perhaps this is what it goes to?
Yep, it was the engage return spring.
Finding that thing in the pan gave me great concern.My manuals came in handy again.
Thank to all who replied. it's intresting to note that every response was the correct anwser.
This site is a lifesaver.
Greg
Greg
