928 Forum 1978-1995
Sponsored by: 928 Specialists
Power Steering Leak
Old Mar 17, 2003 | 10:14 AM
NYDolfan's Avatar
NYDolfan
Question Power Steering Leak
Getting ready to get the OB out of semi-hiberbnation. Driven it a few times over the course of the NY winter but it's been sitting for 6 weeks with all the storms we had lately.
Took it outside yesterday to get it warmed up and noticed power steering fluid on garage floor. Not much mind you. PS Resorvoir still measures on the dip stick. Rack replaced 12K miles ago.
Search on list yielded suggestion to drain fluid - cut top end of hose and reclamp.
Does this sound like the best place to start? Also - where on the PS dipstick should the level be?
Old Mar 17, 2003 | 11:01 AM
Erik - Denmark's Avatar
Erik - Denmark
Post
Pete,
Go under the car and find out from where the oil comes - First lift/open the rubber boots at the steering rack, if you have oil here the rack is leaking - Next possibility are the hoses from/to the reservoir, pumps and rack
Old Mar 17, 2003 | 05:54 PM
NYDolfan's Avatar
NYDolfan
Post
thanks... I'll check tonight
Old Mar 17, 2003 | 07:13 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Post
It's easy to check the hoses by just feeling underneath the reservoir. If one of the hoses is moist, you found at least one of your leaks....do you get any noise from your pump?
Old Mar 17, 2003 | 07:46 PM
TJQuill's Avatar
TJQuill
Post
Most common leak is from loosened hose clamp at resevoir. If you can't tell because everything is grimy and greasy, clean the hoses, drive the car around the block, then check. Usually as simple as tightening those clamps down. (I keep meaning to put a dab of light loctite on those, but instead I just retighten them every year or so).
Old Mar 17, 2003 | 08:06 PM
Mike LaBranche's Avatar
Mike LaBranche
Post
Second the leaking from resevoir. Any oppossed?
And an 88 is hardly an OB.
As for level, Owner's Manual should put you in the ballpark.
Old Mar 18, 2003 | 12:02 PM
NYDolfan's Avatar
NYDolfan
Post
Topped off PS tank with Dexron, wiped down hoses, tightened clamps last night. Driving it today in this sunny 60 degree NY weather. Will recheck tonight.
Old Mar 19, 2003 | 10:05 AM
NYDolfan's Avatar
NYDolfan
Post
Still a random drop or two, but it's not red like before. Maybe just leftover that I missed wiping down - will check thoroughly this weekend.
Old Mar 19, 2003 | 11:11 AM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
Post
Third on leaking / loose hose clamp........
One of those unlisted "features" on Gretch.
