928 Forum 1978-1995
Sponsored by: 928 Specialists
Dash, Indicators and Rear lights problem
Old Nov 19, 2007 | 09:19 AM
Cheburator's Avatar
Cheburator
Default Dash, Indicators and Rear lights problem
Plugged my instrument pod back in, turned the key and nothing - no dash illumination at all. Checked the fuse - it is ok. Then the indicator relay started buzzing, rather than clicking and lastly, there are no rear lights, eventhough the fronts work as expected. Any ideas?
The car is a 1990 GT
Thanks in advance.
Alex
Old Nov 19, 2007 | 11:33 AM
Alan's Avatar
Alan
Electron Wrangler
Battery is kaput? check voltage?
what else did you work on? did you pull the central Electric panel too?
Alan
Old Nov 19, 2007 | 11:58 AM
John Speake's Avatar
John Speake
dash ground wire off.....
Old Nov 19, 2007 | 01:54 PM
Cheburator's Avatar
Cheburator
Thanks for the suggestion John. I think I will start from scratch again next week - take everything apart and put it back together, hoping for the best. Otherwise I can see a trip to the Good Dr A...
