928 Forum 1978-1995
Sponsored by: 928 Specialists
ATF leak when when in storage
Old Nov 16, 2007 | 03:58 PM
Mads's Avatar
Mads
Default ATF leak when when in storage
Hi
when i put the car away for the winther (6 months) , it usually loose some ATF from the gearbox. last year i renewed the rubber seal in the lid, but that didn't help, where should i look for the leak ?
Mads
Old Nov 16, 2007 | 05:54 PM
davek9's Avatar
davek9
Mads I have read here that the storage leak is caused by the Torque Converter draining back in to the system and over flowing the Fill bottle; the fix was to replace the rubber seal on the lid.
But you did that. Sorry I don’t know where else to point you to.
Davek9
Old Nov 16, 2007 | 06:03 PM
928SS's Avatar
928SS
Road Warrior
mine does it too... guess they don't like to be neglected
Old Nov 16, 2007 | 06:05 PM
the flyin' scotsman's Avatar
the flyin' scotsman
There are 3 location where the reservoir may leak : the cap or lid has a gasket, where the res. pipe joins the transmission pan there's a O ring and on top of the res. there's a small hose.
I'd check all 3 clean up the area and ensure the level is correct, car running, in netural, warm.
Old Nov 16, 2007 | 06:13 PM
shadowknight's Avatar
shadowknight
I have the same problem and have taken it in three times to get it fixed, as long as I don't let it sit for more than a week im fine.
Old Nov 16, 2007 | 07:31 PM
Jfrahm's Avatar
Jfrahm
I thought there was a little vent in the reservoir cap? If so the gasket might not fix it.
Old Nov 16, 2007 | 07:42 PM
Randy V's Avatar
Randy V
25 Year Member
It's normal, or if not normal, occurs to most 928s.
When the car sits for more than a week or so the trans fluid residing in the torque converter seeps back into the transmission causing the fluid level within the trans to rise and then ultimately leak out thru the vent hole at the top of the trans.
