Blaupunkt Audio ..Tech info required
I know there is quite a number of audio wizards out there and I need your help. I have a Las Vegas cd/radio installed (by previous owner) and unfortunately the audio preamp out cable was not connected to the unit therefore missing.If anyone has the pin out diagram for the preamp connections it would be greatly appreciated. I tried going through a local stereo shop(dealer) and for the past two weeks no info or help. I can't run the sub without it...too bad EH!...anyways I'll leave my email address and If someone can help me I really do appreciate it... Thanks Bill 84 928s
email.. p.b.walpole@sympatico.ca
Hi Bill,
Check out:
<a href="http://www.swstereo.com/" target="_blank">http://www.swstereo.com/</a>
The proprietor of this business is Stefan Weiss.
He is VERY knowledgeable about Blaupunkt equipment
AND most importantly 928 wiring. It is likely that
he can provide you with the preamp out cable you
are missing. Contact information for technical
questions/help is on the website.
Hope this helps,
Brad
'78 <a href="http://www.p-caronline.com/directory/showngo/" target="_blank">928 euro</a> 5 speed
928 Owners Club
Check out:
Hope this helps,
Brad
928 Owners Club
Location: Seattle - it's not Hell, but you can see it from here!
bill,
first, download the PDF manual for your Las Vegas:
<a href="http://www.blaupunktusa.com/pdfs/receivers/lasvegas.pdf" target="_blank">http://www.blaupunktusa.com/pdfs/receivers/lasvegas.pdf</a>
then find a Blau dealer and order the pre-out harness, part no. 8 634 494 218.
here's the wire diagram, but it's in the manual too...
Hey Dave: Thanks for the reply and yes I do have the manual. My problem is that the preamp out for the unit is a multipin plug on the back of the player.It's this cable that is missing, plug and all.The plug for the spkr connections is there and power etc,just the preamp one was not installed by the PO. If I knew the pin out connections for the plug I could make one.
Brad...Thankyou for your reply as well. I tried that 800 number and I guess its not available to my area . I'll keep trying and maybe I can make it through. Thanks Guys I appreciate your help and someday I'll get the sub working..Even if I have to replace the unit...Best Regards Bill 84 928s
Stefan made me a pair of custom cables for my Nevada Blau to use the stock amp. I am sure he can do it for you. He is awesome.
-Tib
-Tib
