Rear wing mounting bolt broken
While adjusting my rear hatch (rattles), I noticed one of the 4 (two per side) rear wing mounting bolts was broken off. I tried to drill it out and replace it, but the white plastic in which it was embedded started coming loose. Any suggestions? The wing seems secure with the remaining 3 bolts in place.
Thanks!
Thanks!
From: Seattle - it's not Hell, but you can see it from here!
you can either leave it alone or expect a chunk of wing to come with it. then you have to try and p[ot in a new stud. fiberglass resin might do it, or epoxy-patch...
