auto trans problem
my 85 auto is not shifting correctly, it would shift into 2nd gear and stayed in 2nd gear, the problem would go away after i shut off the car and let her sit for a couple of minutes, anyone has idea what the cause might be.
Low transmission fluid.
Car parked. Idling in Neutral. Resevoir is underneath in back, middle, passenger side. White plastic square, red cap. The fluid level should be between the two lines scribed on the side with the fluid warm/hot. You'll need a good flashlight to see them. Drive it around a bit before you check it.
You'll find various approaches to adding fluid in the archives via the Search link at the top.
Good luck.
Good luck.
Thats the same problem I've had a few times. Also, if you nail the gas and it goes into first, it will stay there until you shift to neutral and then back to drive, but then that only gets you back into 2nd gear. And yes, low ATF is the culprit. Now just find where its leaking!
i found out that i was low on trans fluid, i added some to the lowest mark with the engine off than drove around for about 8 miles and with the car running and in neutral added more fluid so it's between the min and max marks, however when i shut off the car and waited about 10 minutes the fluid was full, i think it might overflow if i remove the cap, did i do something wrong?
