Now for something completely different (backwards starter motor - RV)
Team Owner
I am working on a 85 928 auto 32 valve, I was under the car chasing a elex gremlin, sometimes she`s a charging and sometimes she`s a not.
Anyway as I was tracing wires I got to the starter and lo and behold the solenoid is facing the left exhaust manifold as well as the harness being routed above the starter to make the connections , I plan on removing the starter and turning it around,so the solenoid faces the oil pan.
Has anyone ever seen this before???
Could the starter be from a different application.?
Before you ask I dont have any pictures but i will take some later. Thanks for your thoughts, Stan
Matt
Artist Formerly Known As 84totheFloor
I can't recall that the starter mounting would allow for reversibility. Nor can I see how the orientation would effect any change.
However, you are da guru, not me.
