Overfilling PS reservoir = bad idea (Newbie autocross observations...)
Archive Gatekeeper
I did about 10 90-second passes at a local PCA autocross yesterday. I learned a few things:
#1- if you spin a 928 with the digital dash, the oil pressure sensor sets off the 'insufficient oil pressure' warning on the screens, which also sets off a slowly blinking red warning light on the gauge itself. This recurs every few minutes and persists even after you turn the ignition on and off. When it went off I had a heart attack, but figured it was a very transient thing, and the car ran fine the rest of the day. This was on fresh Rotella 15W40, 9 qts (upper mark on the dipstick), I'd let it idle until warm before each run, by the 4th run of each session, oil pressure at idle was 2.5-3 bars. There was a ~1000 (!) foot straight on the track, I got to about 80 mph in 3rd before braking. I need to learn how to heel 'n toe better....
#2- I had the PS reservoir filled up to within 1/2" of the base of the, threaded neck, and after each set of 3-4 runs, the steering somehow felt 'overboosted' compared to cold. This was probably due to heating up the tires (which I had at 36/44 cold), but the other issue was that I spewed a few oz of PS fluid all over the reservoir, hoses, left dist cap, and coil. Made a real mess. I guess I should actually towel off the little dipstick on the lid and see where 'full' actually is.
#3- My instructors (great, both of them) both commented that I wasn't even close to using all of the brakes. By the time I was hitting them hard enough to really kick into ABS, I was missing the turn in's at the 180's (2 of them on the course) I gotta go back and get it right!
While there's a ton of downtime at these events, I stongly recommend that everyone get out there and put their car through its paces. I was probably the slowest guy out there but I bet I learned more than anyone......
All in all a great day, I've got a lot of improvin
We need to get you out to the POC short track series at Willow springs. Each day you get 5 run groups 15-20 minutes each so well OVER one hour a day on the track ! You got less than 15 minutes...but still a great chance to run the car.
Archive Gatekeeper
Man, the oil pressure warning is persistent, every 10-15 seconds while driving. I need to disconnect the battery for a minute or two.....
![](https://webfiles.uci.edu/redwards/public/Insufficient%20Oil%20Pressure%20wanring%2011-12-07.jpg)
Rob,
AutoX my '91GT 3 weeks ago and did not experience any of your problems. Ran about seven 60-70 sec. passes. I'm doing it again this Sunday. BTW, I'm running 38/40 tire pressures.
Chronic Tool Dropper
Rob-- two wires on the sender by the oil filter. One for the gauge, other is a switch I think.
Archive Gatekeeper
Yep, Redline D4 ATF. Good to know it's not a fire risk, but I busted my *** getting that corner of the engine bay dry after the Exxon Valdez-like slick on everything when I bought it. Ah well, more garage time......
