928 Forum 1978-1995
Sponsored by: 928 Specialists
Radiator Which side up ?
Old May 29, 2003 | 04:07 PM
Richard Lang's Avatar
Richard Lang
Thumbs up Radiator Which side up ?
Starting to do Timinig belt and etc. Noticed the warning for the (electronics warning)on the bottom from PO's work (I assume). does it matter which side is up or should I take it out and turn it over. ?
Richard
Old May 29, 2003 | 04:23 PM
Drewster67's Avatar
Drewster67
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Richard Lang:
<strong>Starting to do Timinig belt and etc. Noticed the warning for the (electronics warning)on the bottom from PO's work (I assume). does it matter which side is up or should I take it out and turn it over. ?
Richard</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Please clarify?.
The radiator - look for the drain plug and install it as it should be.
Old May 30, 2003 | 10:28 AM
Johan928's Avatar
Johan928
Post
Richard,
When standing in front of your car, there should be a temperature sensor on the bottom right front of your radiator. It's difficult to see. If the PO had the radiator repaired (ie: new plastic end tanks and seals), the repair shop might have accidentally put the end tanks on to where the aluminum part of the radiator was reversed.
If you turn the radiator over, I think you'll have a problem regarding your temp sensor that threads in on the front lower side of the radiator.
John
Old May 30, 2003 | 04:41 PM
Richard Lang
Post
John,
thanks it looks like the repair shop put them on that way, the temp sensor is there on the right side.
Richard
