Air Pump
John,
Thanks, I wanted to verify I wasnt altering another function other than pumping air into the cat.
I plan to use a bolt on x style test pipe set up for a DE event, then switched back to the cat for state inspection / normal use.
Just wanted to be sure it would not create a problem in some other function during the time it was off and driving to / from a track.
On my 79 928 the air pump ceased up, the previous ovner removed the belt and thereby removed the cooling from the fan connected to the above mentioned pump.
At my Porsche/shop dealer they told me it was a "not needed" item. They dismounted it and instelled a Japanese(????)modification. A bracket with a spinning wheel. Fan is working fine and no problems with overheating.
I do not have a cat.
Geir.
"I have found that sufficient amounts of alckohol produces the same effects as drunkeness"
Geir.
Linus - Air Pumps coincide with catalytic convertors. Their two purposes in life is to reduce emissions and to reduce horsepower. Even though I have a Euro Model, we still need cats or we cannot register with the DMV.
I will say this, if you live in a City such as LA - you would be glad the cats are in place. Man is it thick there.
Kudos
Kudos
