View Poll Results: What is your typical fuel octane rating?
87 octane
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
42
30.88%
89 octane
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
10
7.35%
91 octane
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
33
24.26%
93 octane
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
51
37.50%
Voters: 136. You may not vote on this poll
Octane poll for 16V cars
#46
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
That sounds right. 87 was horrible. Id been using 89 exclusively prior. Jason
#47
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
"Fuel Recommendation
Minimum octane rating is 91 RON (87 CLC rating on U.S. fuel pumps).
The CLC octane rating is usually 4 points lower than the RON rating:
91 RON equals ................ 87 CLC
95 RON equals ................ 91 CLC"
928 OWNER'S MANUAL
MODEL '82
page 63
#48
Basic Sponsor
I run regular 87 in my pre 82 US cars with no problem.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#49
Any other experts want to chime in![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I have no idea what the facts are anymore. I think I'm gonna run what my car seems to like no matter what that may be.
#50
Hi,
I can't vote on this poll because here in Portugal we only have two options, 95 and 98 octane fuel.
Of course I only use 98 in my 83 S, as recomended by the owner's manual and the sticker near the fuel filler!
Regards
Regards
#51
928 OWNER'S MANUAL
MODEL '82
page 63
Dennis
#52
#53
Administrator - "Tyson"
Lower octane does burn faster, he is dead on with this statement. High octane gasoline burns slower than low octane gasoline. The slow burn prevents engine knock when cylinder pressures are high.
This isn't rocket science and blasting Lizard for mis-using one word is a bit unnecessary.
A low compression engine like the US 16V (I'm not sure the real CR of the 83-84 cars so that's up in the air) with the very tame ignition curve in theory will be just fine with 87.
Factors that get in the way:
Age = carbon buildup, creates hot spots and in a round about way raises compression ratio
Quality of parts = Running the correct spark plugs? How good are the wires, rotor etc.... I've worked on ill running cars "fixed" by installing the correct OEM parts versus "high performance" aftermarket.
My friend has a 1.8t VW he's always putting **** aftermarket parts on (he falls for all the ads). His car was idling funny and knocking like crazy on the upper end. He put in some $20 a piece go fast spark plugs. After putting in $2 Bosch Coppers his problems went away.
Quality of gas, go to BFE and fill up on 87 that's been sitting there for 8 months..... This is why I stay away from "off the beaten path" gas stations if I can.
So.....
If your low compression motor has clean cylinders / pistons, timing is stock, all parts are in good working order, valve guides / seals are not leaking etc..... good quality 87 octane will be fine.
I'm curious how many people pull their spark plugs on a regular basis to check for detonation.
On a side note, I run 87 in my 79 track car
#54
Just did mine and no sign of detonation. Only half issue was one bank was getting more fuel than the others by the look of the plugs.
#55
What I am saying is that CLC is the old standard used in the US and RON is the standard used in Europe. Now, US pumps rate the octane based upon an average of the two standards. i.e. M(CLC)+R (RON)/2=the new rating used in the US. BTW there is an older thread here that explains it much better than I could.
Dennis
Dennis
#56
#57
Lightstriker,
Lizard was talking about 16 valve cars (note the thread topic) which don't have 9.5 or 10 to 1 compression ratios. They were engineered to run on lower octane so any gains by running a higher octane would be minimal and certainly not enough to offset the higher cost.
Dennis
Dennis
As far as I know, the US ran on 9:1 ratio, and Europe ran on 10:1 ratio.
1984-85-86, ran on 9.3:1 (US) and 10.4:1 (Europe)
Next what? You will tell me that dull black car cannot be picked by laser and radar?
#58
#59
As far as I know, your statement is generally wrong.
As far as I know, saying "as far as I know" doesn't give you the right to insult anyone.
Bye, as far as I know.
Dennis
#60
As far as I know, the early US and ROW 928's had the same spec's even though the ROW 300HP engine may have had a higher compression ratio.
Dennis
Dennis
So, if they are wrong, I would like to know! Cause I was expecting that thing to be correct.... and I'm basing my repair on it!
