928 Forum 1978-1995
Sponsored by: 928 Specialists
What are good compression test numbers?
Old 11-03-2007 | 03:57 PM
  #31
StratfordShark's Avatar
StratfordShark
On an S4 (warm) I recently measured:
1-204
2-200
3-200
4-215
5-214
6-180
7-212
8-202
I don't know if the gauge was reading high or if the ROW S4 engine (it's a UK car) has a slightly higher compression ratio.
Cylinder 6 looks the odd one out but not grossly. I did the 'wet' test with oil on that cylinder and it shot up to about 250psi
It's an '88 with 127K miles.
Adrian
Old 11-03-2007 | 04:02 PM
  #32
Lizard928's Avatar
Lizard928
cyl 6 would give me abit of worry, and when you did the wet test how much oil did you put in
Old 11-03-2007 | 08:34 PM
  #33
the flyin' scotsman's Avatar
the flyin' scotsman
I'm reading this thread and thinking I just got back from a run and there might not be many opps to get her out before snow & ice.............the plugs are out as is the FP fuse..............BRB with the comp. readings.
Old 11-03-2007 | 08:37 PM
  #34
StratfordShark
About 15ml - a tablespoon. It may be a sticky piston ring but doesn't seem to be bore wear given pressure went up with the oil.
Old 11-03-2007 | 08:50 PM
  #35
Lizard928's Avatar
Lizard928
agreed if the reading goes up with oil, it indicates just ring wear, but that is a serious amount it went up by, I would have expected more oil to have been put in there to get that reading
Old 11-03-2007 | 09:36 PM
  #36
StratfordShark
I agree and am at a loss to explain why that cylinder magically created a greater than 10:1 compression with the ring temporarily sealed. Will live with it till some other symptom shows up.
Old 11-03-2007 | 09:57 PM
  #37
the flyin' scotsman
My readings are very consistant but not from bank to bank:
1~ 4 : +/-170psi
5 ~8 : +/-150psi
Cam timing?
Old 11-03-2007 | 09:58 PM
  #38
Lizard928's Avatar
Lizard928
Malcolm, yes that is correct to say that your valve timing is off.
Get your hands on porkens valve timing tool and set them the same.
Old 11-03-2007 | 10:17 PM
  #39
the flyin' scotsman
I've got Ken's timing tool and set the cams prior to the tbelt project............hmmmmmmmmmmm!
I can reset the cam timing and do another comp test time permiting.....its getting cold.
thx Liz
Old 11-03-2007 | 10:28 PM
  #40
Lizard928's Avatar
Lizard928
imo it is better to set them when the engine is warm as they do move abit when warm.
Old 11-03-2007 | 11:41 PM
  #41
FlyingDog's Avatar
FlyingDog
If only 1ml was needed to seal the ring, you just reduced the combustion chamber size by 14ml... your combustion chambers are only 60 or 70ccs.
A compression test should yield a number 17-22xCR. It seems that below 14-15xCR is bad.
Old 11-04-2007 | 06:42 AM
  #42
StratfordShark
But if I have 5000cc and 8 cylinders then each cylinder is 625cc?
Old 11-04-2007 | 11:39 AM
  #43
the flyin' scotsman
Stratford.............the combustion chamber is measuerd with the piston at TDC which leaves only the volume between the piston crown and the cylinder head.
Old 11-04-2007 | 12:24 PM
  #44
StratfordShark
Doh! Thanks for explanation.
Old 11-04-2007 | 08:18 PM
  #45
Nicholbry's Avatar
Nicholbry
So, it is possible to have +/- 10 it seems. Thanks for the info.
Quick Reply: What are good compression test numbers?
