928 Forum 1978-1995
Sponsored by: 928 Specialists
What IS that button by the seat?
Old 11-02-2007, 04:17 AM
Ian928
Ian928's Avatar
Haha, mine does not work either!
But as to the comments about US drivers being trusted to this system, the headlights are adjusted manually (at the shop) with the adjuster at the top, so you are not able to adjust the beam higher, only lower(to compensate for more weight in the boot). So at least you are not able to bother other drivers if you adjust it wrong.
Old 11-02-2007, 09:01 AM
jon928se
jon928se's Avatar
Originally Posted by Nicole
From what I hear, those headlight adjusters are a constant source of trouble on the European 928s. We can almost consider ourselves lucky we don't have them...
No trouble
Installed a new system two years ago on the SE (after 5 years with a non workiing system) new system now only works on one side - no trouble.
Old 11-02-2007, 11:04 AM
Alan
Electron Wrangler
Alan's Avatar
For the hydraulic - yes - troublesome. Electric - seems pretty reliable (if over complex).
The adjuster ***** & skirts between the 2 look almost the same.
Originally Posted by Cheburator
Opens the boot, but I think you need to have the driver's door open to activate it. At least that's the way it works on my RHD '84 S2 5spd and LHD '90 GT-R
Either door - but only if they both trigger the interior lights via the pin switches...not always true of course...
Alan
Quick Reply: What IS that button by the seat?
