928 Forum 1978-1995
Sponsored by: 928 Specialists
Transmission cooler line leaks
Old 05-27-2003 | 01:22 AM
BrianG's Avatar
BrianG
Post Transmission cooler line leaks
I have just been informed that my '86 car(with 75k miles) is leaking transmission fluid from the coupling in the torque-tube tunnel.
I searched the archives and didn't find any mention of this. Is this common or uncommon?
I find that the forward 1/2 of the line(s) are EXPENSIVE and are back-ordered to Germany. <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" />
Any options? fixes?
Also, apparently the plastic filler unit is "oozing at the seam"..... does this sound reasonable?
Old 05-27-2003 | 11:29 AM
tresamore's Avatar
tresamore
Photoshop Bully
Post
Same problem on my 87. Someone already tried a cheesy hose w/ clamps over the metal tubing repair. I'm going to get compression fittings to fit the metal tubing and use some Earls aluminum fittings and braided stainless hose. You could go w/ the compression fitting over the metal tube w/ a barb on the other end and use a good quality hose that will take some pressure. I do have a leak back at the trans also but haven't looked to see if its the tank yet.
Quick Reply: Transmission cooler line leaks
