Can someone point me in the right direction please. Also, my parts CD has just died on me as well thus can someone also give me a part number as need to replace this Warm Up Regulator.
Syed, if you are referring to the idle speed valve (ISV) it is hidden under the intake manifold and not visible in the link. In the 3rd pic down, hose #12 curves under the manifold, and connects to it.
S4+ 928's do not have warm up regulators...only early ones did...however the temp II sender (#2 in photo) sorta acts like one....so check its impedance vs the published ranges to see if its working properly
