Cam Chain Tensioner Replacement Interval
Is there a recommended interval for the 928?
If so;
How often should the assembly ($315 from dealer) be replaced?
How often should the nylon ramp from dealer, $25 from Zims) be replaced?
There is a long thread titled "Cam Chain Tensioner - Plastic Ramp" in the 924/944/951/968 board from August that has a picture of the part in question.
Thanks in advance.
The cahin has a nylon ramp/guide that is held in position with a hydraulic tensioner.
The part number for the ramp is a 928 part so I am assuming it the same in the 32valve 928 motors.
The motor is working fine right now, I'm thinking of doing this as a preventative measure.
Thanks again in advance
As a result, 928 owners don't usually replace the tensioners.
I am glad to see Wally's explanation. I looked at the picture on the link. The plastic in the 944 is orange. It seems it was a different color on the 928. The 944 ramp seems longer too. Perhaps the 944 plastic is more brittle, and receives more levered force.
I was told that the chain, and check valves should be replaced. I doubt you can replace the chain without removing the cams. I have a procedure for removing cams without use of special tools on Greg Nichol's site. You need to be very careful, and loosen bolts slowly, in a diagonal crossing pattern. You need Loctite 574 for cam towers. I would replace the rubber mentioned in my earlier post too. If I can be of help, send me an email, or respond to this board.
From what I understand, the nylon ramp starts out white then become orange.
I called a local repair shop that specializes in Porsches, and was recommended by the parts guy at the Porsche dealer.
I was told the cam tensioner is replaced when it goes bad. He offered to listen to my cam with a stethoscope to see if the valve cover should be opened/removed.
I think I'm just gonna change the nylon ramps on the tensioner next oil change when the car has 69K just to be safe.
I will then listen/monitor for the chain to start slapping, and when it starts slapping a bit, I will replace the hydraulic tensioner. That is unless someone finds something to tell me to do it sooner.
That sounds good. I quess chain slop would be audible. At that indication, I would replace the chain, and probably not the tensioner. The chain is about $15. Loctite is about $30. Rubber pieces should come in a head gasket set... don't know that cost. Mine also has a check valve. It can be called a hollow bolt. Oil passes through it, and is prevented from back flow. Therefore, it is a check valve. Mine were $15 each. They can go bad... cheap preventive maintenance. I was also concerned that your rubber would leak oil after it was disturbed.
Note that I keep revising my earlier post periodically when I think of more things that I replaced.
Good Luck,
