car problems after retensioning
#31
Unless you main the oil return hose from the filler to the pan, I have no idea what oil line you would be removing. If that is the line, you probably didn't puke out much oil and you certainly didn't cause oil starvation.
Pull all the plug and coil wires, then reconnect them using the sticker that should be on your radiator for reference. There should be 4 cylinders and 1 coil connected to each distributor. The noise could be gas firing in your exhaust.
#34
#37
i just remembered, i drooped a screw on top of the intake manifold and it fell in.Is their any was to fish it out without taking the intake manifold off? also here are the pictures.
http://aluminumfabinc.com/porsche/car%20038.JPG
http://aluminumfabinc.com/porsche/car%20039.JPG
http://aluminumfabinc.com/porsche/car%20040.JPG
http://aluminumfabinc.com/porsche/car%20041.JPG
http://aluminumfabinc.com/porsche/car%20042.JPG
http://aluminumfabinc.com/porsche/car%20043.JPG
http://aluminumfabinc.com/porsche/car%20044.JPG
#40
3 quarts as in 6 litres?...........thats most of the oil.
Is that the amount you put back in?
Assuming your driving a LH drive car those lines are the engine oil lines to the rad.
If you change the oil and filter you need about 8-9litres of oil. Hopefully there's no serious engine damage.
#41
rentension problems
i placed the screw on top of the intake manifold. The screw then slipped into a hole on the top of the intake manifold and fell in. I bought a spring claw i am going to modify it with the magnet from the magnet pen i bought, then shove it in the intake manifold and hope I find the screw.
#42
#44
Have fun!
#45
I think ol' '88 is having some fun with us in exchange for the hard time he received on the board last week when his rudeness resulted in a bad reception.
Put some honey on the end of that magnet pen, and you can coax out any bears hiding in there while you're at it.
