Rear hatch; why use a motor to open it ?
Just curious; does anyone have the background for Porsche's decision to do this ?
My own motor runs, but only opens the hatch in about 20% of my attempts; for the remaining ones, I have to resort to using the key.
Recall reading elsewhere here, that the rear hatch opening motor system is one of the most complex items in the 928s.
Thus puzzled about the reason for selecting such a way to do it - why not just a simple cable pull (which worked just fine in my first-car Toyota)
Cheers,
Erling
Cheers,
Erling
Cheers,
Erling
Cheers,
Erling
Mike
Erling, excellent point.
This may very well be a case of over-design ("Let's make the world's most advanced hatch opening mechanism!") followed by under-funding ("To make up for the huge cost overruns from the design department we'll use cheap materials").
I do not relish the idea of converting a 928 to cable-pull - that's a lot of planning and tearing into the car, then a lot of bracket fabrication, maybe some welding and riveting.
Electron Wrangler
Really I don't know - a simple cam actuator with a solenoid drive should have been enough - no parking mechanism required...
I suppose we can be grateful it isn't vacuum actuated though...!
Sometimes it appears the engineers weren't well enough supervised and started "overdoing it"...?
Alan
Alan
My 1967 Buick Riviera has a vacuum actuated trunk release. It has worked perfectly, never any problems. My grandfather (he purchased the car when new) was always expecting it to quit working, but it outlasted him. Open the glovebox, push the little red button, hear the pssssstaaah of the vac system, trunk opens every time.
Rich
Rich
Thanks for the input guys
"Ein kabel-pull ?? Idiot!! Dummkopf!! Dis is supposed to be unseren state-of-the-art auto!! Wir kann nicht use such ein simple system! Machen something mehr kompliziert bitte !!"
Cheers,
Erling
Cheers,
Erling
When my trunk opening clock-works retired, I replaced the unit with a simple solenoid operating the stock latch-release flag mechanism, thinking that this would finally resolve my intermittent functionality of the remote trunk release. No dice! Half of the intermittancy problem is actually the issue of the alignment of the two mating parts of the locking mechanism. If they are mis-aligned, the stock flag mechanism cannot move the nylon latch far enough to disengage it from its mating latch-piece.
After messing around with the latch alignment (unsuccessfully), I decided to modify the latch-release flag part by making the flag tab project further. Thank heaven for TIG!! A 50% increase did the job. Releases are now 100% reliable, and I suspect that this modification would have a similar effect on release reliability, even if still clock-works driven.
On my 1990 S4 the pull **** will only activate the motor to release the hatch if one of the doors is open. As a consequence, pulling the **** accidentally (??) while driving will not release the hatch (assuming you're not driving with the doors open, of course!).
So could there be some safety reason for the complicated set up? A simple cable could release the hatch while in motion?
Nah, can't be - more likely simply over-engineering!!
Erling, by placing a 1 Euro coin under each edge of the body-mounted latch plate (near each of the hex head bolts) cured my intermittent hatch release problem. This fix has worked for others too.
Regards
Regards
Apart from the hatch and receiver getting misaligned, the bush from the link to the operating arm can break up and produce enough slop to prevent correct operation. I fixed one by making a brass bush (7mm od, 5mm id), and retained it with a 2-56 screw into the arm. Shouldnt be too hard to find a piece of tubing to do the job....
jp 83 Euro S AT 51k
jp 83 Euro S AT 51k
Electron Wrangler
DaveO - yes they deliberately went to great lengths for that safety feature....
It does make you wonder how much downforce the wing makes - that they are still worried it will fly open...
Who wants to test this...?
Alan
Alan
Owns the Streets
Needs Camber
Needs Camber
Alan,
I once drove about 200 miles (upstate NY to NYC) without having the hatch latched. I'd closed but forgotten to latch it with a nice forceful push.
Mostly highway driving. 60-80mph stuff. Only when I got back to bumpy NYC did I hear a strange rattle from the hatch bouncing up on the bad pavement.
And that's with non-collapsed hatch shocks.
You guys shouldn't complain. Hans und Franz could have duplicated the hatch lockdown unit for the front hood. But we all know that 928's are so reliable that owners rarely open the hood.
Cheers,
Erling
