Differential Fluid Question
I have an automatic and the owner's manual lists SAE 90 hypolid oil. If I change the oil can I use Castrol Syntec SAE 75-90?
If not, is there a synthetic 90 wt gear oil I can use?
A multi grade oil of 7 5 / 90, i s perfectly safe to use in a place of seasonal changes.
If your rear is posi, you will need to add a posi additive to the oil.
<a href="http://www.1st-in-synthetics.com/gear_lube.htm" target="_blank">http://www.1st-in-synthetics.com/gear_lube.htm</a>
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
FWIW - I used Mobile 1 75-90w when I replaced my fluid. No problems to date.
A hint though - be sure to REMOVE THE FILL PLUG FIRST before draining the R&P housing.
hth-
hth-
mobile synthetic is OK but Amsoil is much better in my experience. Here is another believer:
<a href="http://members3.boardhost.com/928s4vr/msg/24761.html" target="_blank">http://members3.boardhost.com/928s4vr/msg/24761.html</a>
