Is this the pulse sender?
Learning as I go along. Is this the pulse sender and is it the sender for the tacho?
I borrowed David Schmidt's picture.
Thanks !
Thanks !
Supercharged
Yes, that is the impluse sender, but I do not know if it is used for the tach. This is used to tell the EZK brain that the engine is turning so send a spark.
The bolt may be missing because someone tried to remove the sensor, an couldn't. They can become quite stuck...
I would replace the bolt as this is one of the most vital sensors needed to keep your engine running !
