928 Forum 1978-1995
Sponsored by: 928 Specialists
Ok?? (another wheel thread - RV)
Old Oct 16, 2007 | 03:14 PM
layton108's Avatar
layton108
Default Ok?? (another wheel thread - RV)
So I've been searching all over the forum for bolt pattern for a 1980 928. I want to upgrade my wheels but cant figure out what i want along with what size would fit best. Also I like the look of having really wide tires in the back not ridiculously wide but sticking out a little is there any benefit to this? Ive seen it done before thats why I'm asking
Old Oct 16, 2007 | 03:27 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Found in the "New Visitor's thread" above:
https://rennlist.com/forums/928-forum/270800-is-there-an-official-928-wheel-offset-thread-now-post-your-wheel-sizes-and-offsets.html
https://rennlist.com/forums/928-forum/253898-who-s-got-the-coolest-wheels-gimme-pix.html
Old Oct 16, 2007 | 03:33 PM
Jim bailey - 928 International's Avatar
Goggle... " Porsche bolt pattern ".. and you get 5 x130 mm in about 2 seconds
Old Oct 16, 2007 | 07:14 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
"sticking out a little" is the same as "fenders hit the tires and cut them on turns" in the rear. Find a set of wheels and spacers that give you a full wheelwell but leave some clearance for wheel travel inside the lip. There's a technique with a hair drier and a baseball bat handle that can sometimes be used to roll the lip of the wheelwell arch just a little, to give you a tiny fraction of an inch more if that becomes necessary. With tires that fill the available wheelwell width at the top, you'll end up with a lot of road debris sprayed on the rear section. Fair warning!
